Pearl Expert Pro Upgrade v10.1 DMX
brianlights
Postby brianlights » 03 May 2018, 01:13
Hello all,
I just finished upgrading a pair of Pearl Expert consoles to Pro spec and Titan v10.1.
Now i've never bothered to patch more than 10 lines or so to the desk, but I'm about to head out on tour and we've set up the rig as 14 lines.
I can patch to the node in the TitanNet overview, however the Expert Node shows the 12 lines on the left and the 4 physical outputs on the right. When i assign 16 lines, it says 16/12 with an exclamation point in a yellow triangle. Is the Expert still limited to 12 as it used to be, or will it actually spit out 16 lines of ArtNet or SACN as the manual states Titan v10.1 consoles can?
Thanks,
Brian
Brian C. Lareau
Lighting Director
http://www.brianlights.com
brianlights@gmail.com
clublights
Re: Pearl Expert Pro Upgrade v10.1 DMX
Postby clublights » 03 May 2018, 22:13
it should output the 14 fine
Users browsing this forum: No registered users and 98 guests
