HTP as LTP
Tumbleweed
HTP as LTP
Postby Tumbleweed » 26 Apr 2018, 21:45
I made a key frame shape on a color wheel that I control the speed with a fader. What I want to happen is when I barely tap the fader, the HTP attribute, the dimmer, needs to go to 100% immediately.
Can the Avo be set to ignore HTP for a fader, ie, treat the dimmer like it's LTP, which is the opposite of Mode 2?
(Tiger Touch running 10.1)
question 2... On my fader wing, the console lamp doesn't work. Is there a setting I'm not finding somewhere, or do I need to have my guy open it up again.
Re: HTP as LTP
Postby Gregory » 27 Apr 2018, 13:17
You can do this if you set the Always On curve on a cue which is set to Mode 1/2/3, note that the Always On curve and some others do not work on Mode 0 cues.
As for the desk lamp there should be level controls on the wheels in System mode, there may be multiple pages of these and a toggle option at the bottom of the menu. For testing purposes you can also open USB Expert Console and select the wing panel and adjust the desk lamp brightness from there. If you are using an LED lamp the direction of the current may prevent the lamp from working.
