Hi.
Does API work with simulator?
I put in browser http://192.168.43.171:4430/titan/get/System/SoftwareVersion and I get: <string>Titan is unavailable.</string>
Using demo api and AvolitesWebAPI/HTML/admin.html when I insert my IP I get: Service unavailable.
What am I doing wrong?
Cant use API
Re: Cant use API
Unfortunately WebAPI works only with hardware consoles from the Titan Mobile and above - it doesn't work with the Simulator and Titan One.
Re: Cant use API
Ok
Re: Cant use API
In Titan v11 the Web API is also available in the Titan Simulator.
Re: Cant use API
icke_siegen wrote:In Titan v11 the Web API is also available in the Titan Simulator.
Hi, is available also for Titan One?
Cheers
Re: Cant use API
Hi
No, Titan One does not support the API.
What exactly do you want to achieve? Maybe I found another way...
Best, Sebastian
Best, Sebastian
Users browsing this forum: No registered users and 1 guest
