Pearl 2008
Jhoe
Pearl 2008
Postby Jhoe » 19 Apr 2018, 14:59
Hi Guys
Regards on Pearl 2008,
it is possible to use the fader to change the value as you set, sample in color.
i want to set my fader to change the color of my robe spot 575AT
So every time i increased the the slider of my consule the color will change as i set
so guys, it is possible to do that on Pearl 2008???
and if possible please can you give me an idea to test it..
thansk
Re: Pearl 2008
Postby niclights » 19 Apr 2018, 15:41
Try changing the fader to mode 2 ([Edit Times]/<select playback>). The fader will then proportionally adjust the level of the control linearly from the current level to the level recorded. Note that for this to work the attribute must be set to fading. This is defined in the personality file but can be changed in the software via PATCH/[Patch Utilities]/[Set/Reset Instant Mode].
Jhoe
Re: Pearl 2008
Postby Jhoe » 19 Apr 2018, 15:46
niclights wrote:Try changing the fader to mode 2 ([Edit Times]/<select playback>). The fader will then proportionally adjust the level of the control linearly from the current level to the level recorded. Note that for this to work the attribute must be set to fading. This is defined in the personality file but can be changed in the software via PATCH/[Patch Utilities]/[Set/Reset Instant Mode].
so insted of rolling the knob it will automatically tranfer to the fader if you switch to mode 2, how about the rest?
and i am confused because i didnt try this one before but i will try tomorrow
Re: Pearl 2008
Postby niclights » 19 Apr 2018, 16:25
I'm very sorry but I don't understand what you are asking. I think it would be best if you try following my suggestion and then come back if it doesn't help or you are having problems.
Jhoe
Re: Pearl 2008
Postby Jhoe » 26 Apr 2018, 10:36
yes bro i tried the mode 2 on the consule but nothing happens do you have any video suggestions so that i can follow very easily
Re: Pearl 2008
Postby niclights » 26 Apr 2018, 11:12
I don't have any videos, sorry. All I can do is reiterate what I said above about making sure the attribute is set to fading (you will need a VDU connected to see what the current setting is) and that the target (recorded) level is different to the source (current). All this in combination with setting the playback to mode 2 will allow you to set the level of the contol proportionally to the fader level between the source and target values.
