Read Only access to titan possible?
Nexx
Postby Nexx » 08 Apr 2018, 03:27
Is it possible to lock down the titan software so that a regular user cannot modify settings?
We need to be able to leave the software open so that band members can turn on/off the stage lights for rehearsal without the lighting crew being present.
Can we setup a profile or something that would be very restrictive to allow this? For example On/Off button for stage lights.
TIA
Re: Read Only access to titan possible?
Postby Gregory » 08 Apr 2018, 18:42
Not really unless you have an original Pearl Expert where you can turn the key to Run mode and then remove it. Later consoles no longer have the key, as it was easy to lose or break, and in new consoles it is no longer possible to enter Run mode at all. On TNPs in Console Mode the playbacks screen on the front is still accessible when the software is locked however there isn’t an equivalent on other consoles. Another option might be to use MIDI or WebAPI to trigger playbacks when the console is locked, the latter could be built into a webpage. As of v10.1, the software will remain locked when it is restarted.
kimwida
Postby kimwida » 11 Apr 2018, 19:28
Why don't you use handle world??
I've used a handle world for my part time operator.
It just contains very restricted playback buttons.
You can unassign all your playbacks except a few on/off playback buttons in your console.
yyy898
Postby yyy898 » 08 May 2018, 10:59
another thing you can do is lock startup show, this way if they mess something up, you just restart the console and its fixed
Reason: please avoid using offensive language.
Users browsing this forum: Google [Bot] and 47 guests
