Probleme update Motherboard Pearl Rolacue to 2004 (Borris3)
Steeve
Postby Steeve » 25 Jul 2006, 17:54
I change my old motherboard Rolacue for a 2004 version, after a LCD display probleme (resolve tanks for your help), I have a other probleme white the roller, i have only the playback page who is select when i switch on the desk. in program and run (normal and talkover) mode.
When i turn, the good page number is writing in LCD display (normal) and when i created memory, they are created in the good and different pages, the probleme is just in restitution playback. If you know what's append and have a solution thanks for your help.
Le Mortauricain
Postby niclights » 25 Jul 2006, 19:13
It was not necessary to re-post. I will delete your original and leave this at the top in case someone didn't read it.
It is not easy to understand as I think you used a translator program. I suggest you speak to your local French Avolites distributor for assistance.
Mystic
Postby Mystic » 26 Jul 2006, 02:16
steeve> you can also post in french and i can translate this into english
Steeve
Postby Steeve » 26 Jul 2006, 16:26
Suite a un degat des eaux j'ai changer la carte mere de ma pearl première generation (Borris1) par une dernière generation (Borris3).
J'ai le probleme suivant, la page du rouleur de playback ne change pas lorsque je la tourne, je n'ai acces qu'au 15 playback de la page selectionner à l'allumage de la console. Pourtant lorsque je tourne le rouleau, les différentes et bonne page s'affiche sur l'ecran LCD, et lorsque je fait des memoires et des chaser j'arrive bien a les creer dans les differentes et bonnes pages que je selectionne, je ne rencontre ce probleme que lorsque je veux restituer ces memoires ou chaser.
Merci d'avance
Le Mortauricain
Mystic
Postby Mystic » 26 Jul 2006, 17:47
Here is the translation :
Due to a water flooding i had to change the motherboard of my first generation pearl (borris1) to a last generation one (borris 3).
I have the following problem : the playback rollacue page does not change when i roll it, i only have access to the 15 playback that were selected at the boot of the console. however when i roll the rollacue, the LCD show the correct page and changes accordingly. when i create memories and chases, i can create then in the different and correct pages that i select, i only have the problem when i need to playback the memories or chases.
thanks for all.
ps: steeve> t'es dans quel coin de la france ?
Steeve
Postby Steeve » 27 Jul 2006, 08:44
Je suis vers besançon
Le Mortauricain
Mystic
Postby Mystic » 02 Aug 2006, 00:30
So there is no clue for this poor litlle french guy ? :) (i'm sorry but i don't know the pearl good enought to try to help, but i'm sure many people here can...)
Postby niclights » 02 Aug 2006, 01:33
I'm not so sure. I've never heard of this and it really doesn't make any sense. Rollercue is switching correctly as is shown in display. Therefore software obviously knows which page it is on.
