VERY URGENT - Expert screen with no image
SJPMC
Postby SJPMC » 05 Apr 2018, 17:45
I was just fiddling with the onboard screen brightness and for some reason the contrast and brightness went to 0 and when I turn my encoders it doesn't go up, show is in 3 hours, is there someone who can save me?
Thanks in advance!
Re: VERY URGENT - Expert screen with no image
Postby Gregory » 05 Apr 2018, 18:29
When the desk is in System mode the wheel A is Contrast and wheel B is Brightness. Start by turning up wheel B and then turn up wheel A to get the desired output, if either value is at zero you won't get much on the display. Another alternative is to open USB Expert Console from the Tools > Control Panel menu on the Touch wing or VGA display. In USB Expert Console select the screen panel on the left and then Screen tab on the right which will give you brightness and contrast controls.
SJPMC
Postby SJPMC » 05 Apr 2018, 18:32
Figured it out a few minutes before your reply by tinkering with, thanks alot, this forum has saved me so many times now!
Cheers!!
Users browsing this forum: No registered users and 75 guests
