Fade in/out times
djsky
Fade in/out times
Postby djsky » 30 Mar 2018, 20:47
I have two playback buttons, one set to dimmer @70 percent, another set to dimmer @100 percent. Both are set to fader mode 2, with fade in and out times at 20 seconds.
What I assumed would happen, is that when the 70pc button is active, and I then press the 100pc button, it would gradually fade from 70pc to 100pc over 20 seconds, however, it only acts upon the dimmer after the first 15 seconds have passed.... so it treats the “time” as from 0pc rather than from the current value of the dimmer.
Is there a way to change this? As most “position” fade times move instantly from where they are and end up at the programmed position over the designated fade time.
Users browsing this forum: No registered users and 62 guests
