BPM Master on Playbacks window
acetaxidriver
Postby acetaxidriver » 22 Mar 2018, 16:46
Hi.
Is it possible to set the TOUCH key profile on a BPM Master, on the playbacks window, to TAP TEMPO?
I moved the BPM Master to playbacks window, set a new key profile with TOUCH --> TAP TEMPO, but the master goes to MAX VALUE.
thanks
AC
Re: BPM Master on Playbacks window
Postby niclights » 22 Mar 2018, 18:22
Unfortunately not at the moment but should be possible in the next version.
acetaxidriver
Postby acetaxidriver » 26 Mar 2018, 23:15
It's possible to copy the macro "TAP TEMPO" into playback window, the macro is in SHOW LIBRARY -> MACROS.
Postby niclights » 27 Mar 2018, 00:00
Yes. This is not quite the same as it will only work on connected chases but it is a good option.
