Pan/Tilt Shape Speed Change
This is a place for people to chare the custom macros they have written.
kimwida
Postby kimwida » 11 Mar 2018, 17:06
Hi.
I want to change Pan/Tilt shape(or any shape) speed by a macro.
I tried this. But no luck.
   <step pause="0.01">Include.SelectPlaybackHandle("playbackHandleUN=1802")</step>
   <step pause="0.01">ActionScript.SetProperty("Editor.Shapes.Speed", 0.1)</step>
   <step pause="0.01">Handles.ClearSelection()</step>
So, I thnk I should use this one...
   Void Editor.Shapes.SetShapeSpeed(Int32 shapeId, Double speedValueToSet, IEnumerable`1 fixtureIds)
To see Pan/Tilt shaped id, I include a playback having Pan/Tilt shape. And fire this code. But it doesn't show the id.
   <step pause="0.01">Handles.SetSourceHandleFromHandle("playbackHandleUN=1049")</step>
   <step pause="0.01">ActionScript.SetProperty("Handles.PendingLegend", Math.ToString(Editor.Shapes.SelectedViewShapeId))</step>
   <step pause="0.01">Handles.SetLegend()</step>
Second parameter might be the speed that I want to change.
And I don't have any clue about the third parameter.
Thanks for any advice!!
jacklighting
Re: Pan/Tilt Shape Speed Change
Postby jacklighting » 28 May 2018, 10:19
want Example for this , shapeid where can i look ?
i Wait for the experts to answer. :D
Best Regard , Sincerely :D
Users browsing this forum: No registered users and 1 guest
