Change some chases' speed to 1x or 2x and show information
kimwida
Postby kimwida » 26 Feb 2018, 17:45
1. A macro that change some chases' speed to 1x or 2x and show information
=> I got 18 chases controlled by rate 1 master. But sometimes I need them to be double speed. So I made two macros change their speed to 100 BPM and 50 BPM. But when I am busy with busking show, sometimes I don't know what speed is now. So I add a dummy chase in which legend show what speed is now. (1.2 sec is 50 BPM and 0.6 sec is 100 BPM.)
1.2 sec.xml
A macro that change some chases' speed to 1x and show information
(4.17 KiB) Downloaded 806 times
0.6 sec.xml
A macro that change some chases' speed to 2x and show information
(4.18 KiB) Downloaded 756 times
Re: Change some chases' speed to 1x or 2x and show information
Postby Gregory » 27 Feb 2018, 13:10
You may wish to consider using the Playbacks.Editor.Times.ChaseSpeedMultiplier property as this allows you to double (2) or half (0.5) the speed of whatever the BPM is set to. This means that if you had some chases that you wanted by default to run faster or slower you could set the BPM accordingly and then set the multiplier to double or half the speed.
I have separated out your posts as this makes it possible to have discussions about the macros you have posted and makes it easier to search the forum to find them.
