Change Legend
kimwida
Change Legend
Postby kimwida » 25 Feb 2018, 17:39
I know how to change legend a cue in a chase.
This code changes first cue's legend to "Test" in the chase which user id is 10555.
   <step pause="0.01">Playbacks.SetCueLegend(handle:"chaseHandleUN=10555", 1, "Test")</step>
But I want to change the legend of the chase not cue in the chase.
I tried this but not worked.
   <step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback",  handle:"chaseHandleUN=10555")</step>
   <step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.SelectedPlaybackName","Test")</step>
And if I want to change a cue or cuelist playback's legend, what do I need??
instead of
Or can I use "chaseHandleUN" for a cue or cuelist playback??
Re: Change Legend
Postby Gregory » 25 Feb 2018, 18:06
Someone else asked the same thing the other day here is the code I sent them:
Handles.SetSourceHandleFromHandle("chaseHandleUN=10555")
ActionScript.SetProperty("Handles.PendingLegend", "Test")
Handles.SetLegend()
Handles.ClearSelection()
You should call ClearSelection once you are done otherwise the handle will remain selected.
kimwida
Re: Change Legend
Postby kimwida » 26 Feb 2018, 04:21
Thank you, it works!!
This code works with a cue or cuelist playback too.
Re: Change Legend
Postby Gregory » 27 Feb 2018, 12:55
The text string should match the type of the handle you are wanting to access. So in theory you should use cueHandle, chaseHandle and cuelistHandle dependent on the type of playback you are using. In this case the user numbers are shared by all three types so will probably work however may have side effects in other cases. There is also a generic playbackHandle that can be used for all three types.
Example:
Handles.SetSourceHandleFromHandle("playbackHandleUN=10555")
Also note that for functions that explicitly require a parameter of type handle such as SetSourceHandleFromHandle you do not need to prefix the string with handle: as it will be automatically converted.
