Urgebt Help! Import Show from Simulator to Titan One
greyhound0815
Postby greyhound0815 » 24 Feb 2018, 06:38
Hello Everyone
As other people alredy mentioned, Titan struggles ah lot with importing Show Files that were programmed on a older Version.
After Pre Programming for 4 Hours, I do have the same problem now! (and no i was not possible to Upgrade before because of no internet connection :| )
I also tried to import Just the Initial File and no Quicksaves, still doesn't work!
The Show ist starting at 18:00 today, and i dont have time to reprogramm anything!
So is there a solution to solve this Problem?
Thxs for soon feedback
Re: Urgebt Help! Import Show from Simulator to Titan One
Postby Gregory » 24 Feb 2018, 09:38
Have you tried to Load the show rather than Import as this is usually more robust at reading show files from older versions? If loading is successful you can save a new version of the file which can then Import from. Titan should normally be able to load shows from the previous version however sometimes can fail to do so if there is an error with the show file for example two fixtures on the same address. It is not possible to load shows saved in higher versions than the version you are currently using.
