I've got a pearl 2000 with the 2004 V1.2 software on it
the desk is in the 1800 serial number range
when just starting the desk it will lock up in this state:
from LEDs lit up are
Fixture page 3
the right arrow in the chase section
Preset fader 1
Memory
Fan
Pan and Tilt
Focus
Shift
the LCD is just " strobing"
internally
the LED display says MAIN
the LED's inside lit up are
TMS
DQM IRQ
KE IRQ
if I set the wipe all link I get this
all the same front screen LED's and LCD state
I get the internal LED to say .. prog then wipe then play locks at play
the LED's lit up are
TMS
DQM LRQ
KE IRQ
if I enter the AVOS ( either with the link or with the 21 and 30 key combo)
I get this
LCD says pearl 2000 +R50 jun 12 2002
and the normal AVOS "stuff"
internally I get the LED display with OK and the "spinning" bar
and only the TMS bank LED on
now after all of this is said and done here are my questions
1 what MIGHT be causing this hardware wise? Failing flash chips??
2. would a noisy main problem be the all troubles I have here?
( we were about to give up on the desk arranged a spare and shut off all the other gear in the house and "suddenly" the pearl started up fine and I could not get it to crash again this leading me to mains issues)
any suggestions and Ideas would be nice to know
thanks in advance
Crashing Pearl.. HELP!!
clublights
clublights
in case anyone wonders.....................
After talking to both Rob and Brad at Avolites America
The issue is either a flaking power supply( since it is running just fine right now I cant confirm that)
OR
Dirty Mains. the house the desk is in is " known" for dirty power issues so we are leanign that way till we can fault check the power supply
OR
