Hi All,
Ok, so a friend and I are working on a show.
We are both programming different songs using the same show file in Titan One Sumulator to be ready for Tiger Touch II on the day.
What we'd like to be able to do is for one of us (Me) to have the master file and then I import the playbacks that he's created from his file into my master show file.
Problem :-
I open my master showfile in Titan ONE/Simulator and then open show library and select his file to import.
When I select his showfile and then the playbacks button, there are none listed to be able to copy into my showfile ?
(I've also mapped all the fixtures in mapper to see if it was that, but it wasn't)
Any ideas ?
Many Thanks,
H.
Problem with Show Library and importing Playbacks
Re: Problem with Show Library and importing Playbacks
Assuming the Titan versions are the same the only thing I can think of at the moment is whether the show library context menu is set to filter unassigned handles (or, similarly, if the handles are unassigned in the imported show, to filter assigned handles only)? Try setting to 'Show All Handles' if not already.
Hi Nic,
Thanks as usual for responding
Yes, I did try that initially, but still no Playbacks.
Both are on 10.1. I even made sure to load and then save both files on one laptop to be sure.
I've logged a support call and uploaded the show files for further investigation
H.
H.
I've looked at your showfiles and can repeat the problem but unfortunately I don't have any ideas why at the moment.
Hi Nic,
Well, at least my lighting problems are never dull !
H.
H.
