Change Legend of Cue in a Chase
kimwida
Postby kimwida » 14 Feb 2018, 18:21
<avolites.macros>
  <macro id="TestSetLegend" name="TestSetLegend">
    <sequence>
   <step pause="0.01">Playbacks.SetCueLegend(handle:"chaseHandleUN=10555", 1, "Test")</step>
    </sequence>
  </macro>
</avolites.macros>
1) Make a two step chase.
2) Remember the chase's user number. i.g) 10555 in my case
3) Put return value instead of "Test".
4) Fire this macro.
5) You can see the return value in the chase's first cue legend. In this code, it change to "Test".
If the return value is int, I don't know how to convert int to string.
I used "Math.Cast.ToString" to convert Int to String. But it doesn't work with return value. I don't know why.
Playbacks.SetCueLegend(handle:"chaseHandleUN=10555", 1, Math.Cast.ToString(Profiles.GetHandleProfileId(handle:"chaseHandleUN=10555")))
Use "Math.ToString" Not "Math.Cast.ToString".
Now it works.
Thanks Sebastian!!
