I am trying to make some macros to change speed, Xfade, Fixture Overlap of some chases.
I found these codes can change them.
ActionScript.SetProperty("Playbacks.Editor.Times.PlaybackSpeed", float:1) ***** Time is BPM not Second *****
ActionScript.SetProperty("Playbacks.Editor.Times.ChaseFixtureOverlap", float:1)
ActionScript.SetProperty("Playbacks.Editor.Times.ChaseXFade", float:1)
I want to set those value to specific user id's chase.
How can I do this??
Put Speed, Xfade and Fixture Overlap value for specific playback
Re: Put Speed, Xfade and Fixture Overlap value for specific playback
You will need to set the selected playback first before you can set the properties, for example you can do the following to select the chase that is connected to the wheels:
Alternatives include setting the setting the selected playback using its Titan ID:
By its user number:
By its location:
ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", Chases.ConnectedHandle)Alternatives include setting the setting the selected playback using its Titan ID:
ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"chaseHandleID=1601")By its user number:
ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"chaseHandleUN=2")By its location:
ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,1,2")Re: Put Speed, Xfade and Fixture Overlap value for specific playback
Thank you!!!
Especially by location, it's more than I want!!
I just made two simple macros but they don't work.
Two macros change overlap(90%) and xfade(50%) three playbacks which are in playback window page 1 and 61, 62, 63 slot.
Somebody help me!!!
Ok, I found these codes only work with "Connected" playback.
How can I make these code work with NOT "Connected" playback???
Somebody help me!!!
<avolites.macros>
<macro id="ChangeOverlap" name="ChangeOverlap">
<sequence>
<step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,1,61")</step>
<step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.Times.ChaseFixtureOverlap", 0.9)</step>
<step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,1,62")</step>
<step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.SelectedPlayback", handle:"Location=Playbacks,1,63")</step>
</sequence>
</macro>
</avolites.macros>Code: Select all
<avolites.macros>
<macro id="ChangeXfade" name="ChangeXfade">
<sequence>
<step pause="0.01">ActionScript.SetProperty("Playbacks.Editor.Times.ChaseXFade", 0.5)</step>
</sequence>
</macro>
</avolites.macros>===========================================================================================
It works by "its user number"!!!!
Looking at your snippets your locations look incorrect as the first number is the page and the second is the button or fader number. As there are only 10/15 playback faders the number 61 you had is much too large, I assume this was the playback’s user number.
I thought it was the location of playback in the Playbacks Window.
The location Playbacks refers to the main playback faders, PlaybackWindow is for the playback workspace window.
