Does anyone know if there is a way to scroll up and down the scroll bar in a workspace window other than using a mouse or finger on the touch screen in Titan Mobile?
It would be nice sometimes to be able to use an attached keyboard (up/down arrows or similar) .
Window workspace scroll bar
Re: Window workspace scroll bar
In the macro library there is Scroll Mode macro which can be used to enable and disable scroll mode on consoles that do not have a dedicated button. When scroll mode is enabled the wheels can be used to scroll around the active window. Using the scroll wheel on a mouse will also work or you can use workspace shortcuts to change the scroll position.
Great , thanks for that - just what I was looking for.
I have allocated the enable scroll mode macro to the macro button labelled Snap. This button has an LED that is lit dim blue when something is allocated to it. Is there a way to make the LED bright blue when the Macro is toggled on by the button (scroll mode active)?
Thanks for all the great support - Steve
The macro used to do this however the functionality was removed due to concerns about compatibility with older software versions.
Thanks for the update. Shame about the LED brightness issue.
