Start a cue list at a specific time each day
LoveTheDark
Postby LoveTheDark » 09 Dec 2017, 21:44
I'd like to start a cue list every day at 4 pm & stop/release at 10 pm. The console will be on 24/7 at an installation.
Can this be done using the internal clock w/o using an external trigger?
Thanks in advance for your help.
Re: Start a cue list at a specific time each day
Postby Gregory » 11 Dec 2017, 22:59
You can use the Clock option in the Timecode menu (or window) and set the times on the cue list as required. If you want the cue list to release automatically enable the Kill Out Of Range Playbacks user setting, note that when you do this the cue list will be killed instantly when the last time in the cue list is reached so you may want to have an additional cue to perform any fade outs. Although the software should run for several days without a problem it is advisable to have the console restarted regularly to ensure that it continues to run smoothly, unfortunately there is no function within the console software to do this automatically.
