Hi all,
I have a couple of questions on the titan console.
1st, mixing colours between playbacks in an LED fixture. Is there a way to do it? I usually get a snap of the colour due to LTP.
2nd, is there any way to index the fixture library after update other than exit from the software (Titan One/Mobile) or power cycle on a console.
Rich.
Titan questions
Dickyc1981
Re: Titan questions
1) Record specific values only (for example clear, select fixture(s) set only red @ 100% in the programmer and record by channel to playback 1, repeat for each of the colour mixing components on other playbacks) and then set the playbacks to mode 2 (fade by fader). Note that you will need to set the colour components to zero before this will work.
2) On consoles you can use Tools/Restart software rather than power cycle but otherwise no, not at the moment.
