Intensity stops working on fixtures (Titan mobile)
snorhyvel
Postby snorhyvel » 09 Oct 2017, 15:57
I was doing some programming and setup on a Mobile, and all of a sudden intensity stops working on a couple of fixtures. If I select one of them and manually set intensity to 100% it looks normal, but in DMX view nothing happens, and not IRL on the fixture either... The only way I solved this was by deleting the fixture and patching it back again...
First it happened on 32 pcs og LED PARs, then on two moving heads. When everything were fixed it happened again on the two moving heads during normal use.
I got one idea from someone that it could be a frozen attribute, but I have not checked that one yet. I hope that someone have any more good idea?
Re: Intensity stops working on fixtures (Titan mobile)
Postby Gregory » 09 Oct 2017, 16:03
Most likely there is a group master for those fixtures which is overriding the level, the quickest way to clear this is to press the Release button and press softkey B Release All Masters.
