capture feature missing/ encoder wheel value assignment
bercic
Postby bercic » 24 Sep 2017, 15:14
hi
when edditing the fixture layout in the built in visualizer via the encoder wheels and the G button set to visualizer. for example want all the fixtures on 9m hight you can only set the value with the wheel not with typing commands.
also normally you can select the @ button by a wheel and type in the value, and that is not possible in the shape engine.
cheers
Re: capture feature missing/ encoder wheel value assignment
Postby niclights » 24 Sep 2017, 16:25
There does appear to be an issue where input values in the numeric entry menu are ignored when wheels are set to visualiser. However, you can enter numerically via the @ menu.
It is true that you currently cannot use the @ keys for shapes but you can enter via the numeric menu (ie. input value and then select parameter from softkey options). I think this is often more useful as it presents options from both pages.
