I have searched the forum and can't find an answer to this... How do you delete a fixture from the Capture Visualiser? I have deleted the fixtures from the patch but I still have the fixtures in the visualiser.
Deleting fixtures
Re: Deleting fixtures
This should work automatically. Make sure the Capture setting 'Auto Update' is turned on.
Unfortunately that doesn't seem to work... I still have the fixtures in the visualiser and can't do anything with them.. I've tried repatching but then I just have more of them... if I locate the newly patched fixtures the old ones that are supposed to be deleted will also locate and all of it's functions work, but the fixture itself doesn't highlight and I can't move them to a different location within the visualizer... I'm at a loss as to why it's doing this.
I have also tried turning auto update off and on but that doesn't do anything either.
What happens if you wipe the Capture theatre?
That did the trick! I'll have to reposition the rest of the fixtures but that's not a big deal.. Thank you very much!
