Flash fade time
htevents
Flash fade time
Postby htevents » 09 Sep 2017, 14:02
I have a few led Matrix fixtures and I have programmed a white blind cue. When the Cue has Global as keyprofile, fade in/out works, but when the keyprofile is in Flash mode, fade times don't work anymore.
I want the Cue to act like a conventional blinder, so I want to program a fade in of 0.5 seconds and a fade out of 1 second, but the playback must be flash.
How can I make it work?
Re: Flash fade time
Postby niclights » 09 Sep 2017, 20:04
Make sure the key profile is set to 'Timed Flash'.
BLightProds
Novice Question: Flash fade time
Postby BLightProds » 20 Jan 2019, 11:47
I have it set to 'Timed Flash' I just can't seem to be able to alter the fade times at all.
Is there a flash times menu?
If so how do I access it?
Re: Flash fade time
Postby Gregory » 21 Jan 2019, 11:54
Nic has answered your other post here.
