When I load a show from a flash drive, does it automatically copy to my console? I would think running a show live from a flash drive would not be ideal...
Should I load the show then save it to the internal disk?
And does file structure matter on the flash drive?
Loading show from USB
frecklestbone
Re: Loading show from USB
It does not automaticly save on the console, just open from usb and save to internal memory.
The filestructure does matter.
In the usb root directory there needs to be a directory called titan inside titan you need a directory shows and inside shows you need a directory with the name of your showfile, inside that directory you can place the actual showfile.
but if you save from titan one / simulator / ... the software does this for you
Once a show file is loaded the software will not need access to the original file as all the required information is either in memory or temporary files. No permanent copy of the show file is made on the hard disk of the console unless a save is performed (auto save, quick save or normal save). Similarly data is only written back to the flash drive when performing a save.
