Reusing Chases of overlap
kimwida
Postby kimwida » 20 Aug 2017, 07:03
I have 8 MHs and 8 LED Pars in my venue and have many chases which have color overlapping from all MHs to all LED Pars.
I am trying to install 6 same MHs and 6 same LED Pars in other venue and reuse the chases.
But my original chases miss 4 steps of overlapping.
How can I fix this??
Should I reprogram all the chases?? :cry: :cry: :cry:
Olie
Site Admin
Re: Reusing Chases of overlap
Postby Olie » 23 Aug 2017, 16:40
What version of software are you using? The way this is handled has changed between V10.0 and V10.1.
If you are using V10.1 then just go in and update the fixture order using the groups. With older versions you need to edit the fixture order in the cues for the chase.
kimwida
Postby kimwida » 24 Aug 2017, 07:13
I am using 10.1.
Do you mean if I update order of the groups which are used in the chases, all the chases are updated automatically??
It's important to me.
Because I have over 2000 songs cue lists which use the chases.
Of course I used the groups when I made the chases.
Thanks!!
