I use v10.1 on Quartz console
Everytime I finish cue programming I press "Clear" key,
but it seems like it clears running shapes and intensity from the programmer,
but all other features stays unchanged.
for example,
I set shutter closed for fixtures, cue was saved and Clear key pressed.
Unfortunatelly shutter remains closed no matter which cue from playback I use
I have to manually select fixtures, change shutter to open and then clear.
Can I change it?
programmer issue
Re: programmer issue
This is the standard behaviour. You can change this by holding the Clear button/[Clear Options] and then toggle softkey C to [Release to Playback Values].
i see,
thank you!!
thank you!!
