strobe rate on fader
jonek
Postby jonek » 26 Jul 2017, 00:00
I use T1, Quartz + wing,
i would like to use 2 faders to control strobe intensity and rate of Atomic3000 separately.
Ia there any way to assign one fader to intensity and another fader to control strobe rate like on external strobo - controlers/detonators?
Regards,
Jonek
https://www.planetdj.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/d/e/detonator.jpg
Re: strobe rate on fader
Postby niclights » 26 Jul 2017, 00:14
Assuming the Atomic is patched in 3 or 4 channel mode:
- Clear
- Select fixture(s)
- Set dimmer @ 100%
- Record to a playback fader by channel
- Clear
- Select fixture(s)
- Set rate @ 100%
- Record to a second playback fader by channel
- Set rate @ 0%
- Clear
- [Edit Times]/<select rate playback>/ Toggle [Mode 2 Fade by Fader]
jonek
Postby jonek » 26 Jul 2017, 01:13
thank you,
Atomic is patched in 4ch mode (dim, duration, rate, effect)
I forgot about that step:
"- Set rate @ 0%"
Thanks!
Jonek
