Keyframe Shapes Fade out doesn't work
daimonback
Postby daimonback » 29 Jun 2017, 13:55
I have a quick question:
I like to work with Key Frame Shapes. So when I record a dimmer shape and I set Fade in and out times, the Playback smoothly fades in and out.
If I do the same, but only record colors, so like green to red, and set fade in/out time but then the Playback only smoothly fades in, but doesn't fade out.
I'm using Titan One with V. 10.1. Am I missing something? And yes, fade in/out are actived, if I use a dimmer shape, it works fine.
Re: Keyframe Shapes Fade out doesn't work
Postby Gregory » 29 Jun 2017, 14:33
Does it make a difference if you change the Shape Size to be Fader instead of HTP Fader? Is the dimmer shape you are referring to a key frame shape or one of the default shapes?
daimonback
Postby daimonback » 29 Jun 2017, 18:55
Thanks for your quick answer. And yes, when I change the HTP fader to Fader it works. I didn't testest this. Thanks a lot :)
Users browsing this forum: No registered users and 136 guests
