Hallo, i have a Titan Mobile and I am wondering how to add already saved cue (for example i have saved it a few das ago) to the cue list (without autoload ).
I know how to add a cue what is currently in the programmer but I didn't figure out how to add already saved cue without autoload. Is it possible? Thanks.
add saved cue to a cue list
alisa.love
Re: add saved cue to a cue list
The easiest way would be to use Quick Build, with this Record Mode selected each cue you select will be copied as a new cue in your cue list (it also work with palettes which can be filtered by your current fixture selection). The other option is to use Include to pull the information from the cue back into the programmer and then record it into the cue list. In both cases the information in the cue list is a new copy so, unlike autoloads, changes to the original cue will not affect the cue list.
alisa.love
Thank you. It helped to solve the issue.
