Get Back To Main cuelist After Busking Chases
kimwida
Postby kimwida » 02 Jun 2017, 07:32
Hi.
I prepare many songs with cuelists.
When I play the main song's cuelist, sometimes I need to fire a few chases like busking.
But after firing the busking chases, to get back the main sons's cuelist , I have to push "cue" button and then the main cuelist button.
It's hard to make a macro because the main cuelist's position change.
Is there any good way to make my life easy??
riscster
Re: Get Back To Main cuelist After Busking Chases
Postby riscster » 02 Jun 2017, 08:10
Yep in User Settings there's a setting called something like 'Auto connect' (from memory) and there are options for 'Chases and lists', 'Lists', 'Chases', 'None'.
If you set it to just cue lists or to none then you can manually connect to the list and it will stay connected.
Alternatively in the connect menu (hit cue once) there is a 'Lock' option that lets you lock the currently connect playback.
kimwida
Postby kimwida » 02 Jun 2017, 10:56
Thank you !!!
You make my life easier!!!
