Timecode Mode
Timecode Mode
Is there a way to change the default timecode setting so that an Avo Quartz always boots up in the MIDI timecode mode? I know I can change the setting by selecting the tab in the timecode workspace, but I would like it to default to this mode on console start-up.
Re: Timecode Mode
The timecode source should be stored as part of your show file. Are you getting any load errors on start up and does it get the correct setting if you do a manual save and load? As an alternative there are factory macros to set the timecode source which you could use. Which software version are you running? If you are running v10.1 you could add the macro to a cue list and set that cue list to run on startup.
