No Lights Responding to Titan One
Emil Lars
Postby Emil Lars » 18 May 2017, 16:47
Soo - My Titan One Software and Dongle Works Flawlessly with every set up I've thrown at it so far - except this one rig with 35 RGB Parcans - 12x JB Systems par 64 Led's and 32x Longman Colorme's
- All the Lights work through a DMX to USB Dongle running on QLC+ / but nothing happens when I try Running them From Avolites - I've Checked that the DMX outputs to Line 1 and I've made sure that the Dongle is set to Tx mode --- Even the On/off Tests on the USB Expert console Yield no Response.
Any Ideas and Help Would Be Apreciated.
Re: No Lights Responding to Titan One
Postby niclights » 18 May 2017, 18:55
If your TitanOne outputs ok to other fixtures this would suggest it's not a problem with the dongle or Titan DMX settings. Similarly, if these lights work with other controllers that suggests there is no problem externally. Therefore I would conclude it's a problem with the patch or, possibly, that for some reason you need to swap the DMX polarity for these particular fixtures and that the other dongle happens to have this swapped though this seems unlikely. Try starting a new show and patch some dimmers to the start address of one of the fixtures and then adjust the levels and see if there is any response. If there is then the problem is in the patch. Also, just in case, are these fixtures split using a buffer as the maximum number of devices on a line should not really exceed 31.
