Pearl Simulator 2004 show file to Pearl Expert 2010
ajay1996
Postby ajay1996 » 12 May 2017, 06:21
Hello I'm new to light programming . Need a help. Can I make show files in Avolite 2004 Simulator o my PC and then use it on Avolite Pearl Expert 2010 , if possible then how ??
I have tried by patching some fixtures in Pearl Simulator and saving it in a pendrive but when i try to load show on Pearl Desk , error comes " No show file found ".
Please help .... Thank You
Re: Pearl Simulator 2004 show file to Pearl Expert 2010
Postby Gregory » 12 May 2017, 13:57
Try using Copy2008 to create the correct folder structure on the USB stick for the console to read it. It was designed for the Pearl 2008/2010 & Tiger consoles however I think it should help with the Pearl Expert Classic software as well.
If you have a Pearl Expert you you may wish to consider switching into Titan mode, for that you can use the Titan Simulator software for offline editing.
ajay1996
Postby ajay1996 » 22 May 2017, 17:13
Gregory wrote:Try using Copy2008 to create the correct folder structure on the USB stick for the console to read it. It was designed for the Pearl 2008/2010 & Tiger consoles however I think it should help with the Pearl Expert Classic software as well.
Can you tell me the path where should I paste Copy2008 on usb
Postby Gregory » 22 May 2017, 17:17
Copy2008 and the show file should be copied to the root (topmost) directory of the USB stick. Then run Copy2008 on your computer before using the stick in the console.
ajay1996
Postby ajay1996 » 22 May 2017, 17:26
Gregory wrote:Copy2008 and the show file should be copied to the root (topmost) directory of the USB stick. Then run Copy2008 on your computer before using the stick in the console.
I have saved my show file in USB-->PearlEXP --> Shows
So should I copy Copy2008.exe in this shows folder ??
Sorry for being so confused , please help
Postby Gregory » 23 May 2017, 00:03
No, put both the show file and Copy2008 in the main/root directory of the USB drive (without going into any sub-directories/folders). With the USB stick connected to your PC, run Copy2008 and it will create the correct directory structure for the console to find and read the show file.
Please note that some of the older consoles may not work with larger, more advanced USB memory sticks. In such cases it is better to use USB sticks which are 2GB or less in size.
