Hi.
As it may be obvious: I'm new to Titan and from Denmark.
I hope for help on this:
I'm able to create a memory/playback/cue for my Involight SBL-3000, so when I move the fader up the colors and intensity I chose in the Attribute editor comes to light and when I move the fader down the light stops. Very nice.
When I make a memory/playback/cue of the Attribute set to Sound Active the lights goes on when I move the fader up, but when I move the fader down the Sound Active-program doesn't stop.
I would like to be able to start and stop the Sound Active-program.
Yours
Jesper
Fixture program doesn't stop when fader goes down
Re: Fixture program doesn't stop when fader goes down
Try setting the release mask for the playback to include 'Special' ([Playback Options]/<select playback handle>/press the S button above the wheel display). You may also want to change the release time of the playback to 0 sec to ensure it happens immediately (alternatively you could change the master release time in the release menu).
Thank you very much. It works. You made a happy friday
