Release mask and grey key executors
4live
Postby 4live » 24 Apr 2017, 11:48
I managed to set up a strobe cue with a global release mask on the intensity (which also carries the shutter attributes on Titan Mobile) and the cue works and releases like a charm when run via the fader. But when I run the cue using the grey flash button above the fader, the shutter does not release and my fixtures keep strobing.
Any idea on this ? Did I miss something ?
Thanks for your help.
Re: Release mask and grey key executors
Postby Gregory » 24 Apr 2017, 16:29
Unfortunately there is a bug which means that the flash button does not follow the Global Release Mask, however you can set the Release Mask of the playback (i.e. not global) which should then work with the flash button.
4live
Postby 4live » 05 May 2017, 16:02
Thanks for your reply, I did a local release which is OK.
Another annoying behavior isthe tap tempo notworking on static playback . I mean I was trying to setup a mester BPB for my shapes and I don't want to consume a fader playback for it. So I tried on the Titan Mobile to assign this to upper right free grey button.
The tap tempo unfortunately does not work on it. Do I miss something ?
Regards,
Nicolas
Postby niclights » 05 May 2017, 16:13
4live wrote:Another annoying behavior isthe tap tempo notworking on static playback . I mean I was trying to setup a mester BPB for my shapes and I don't want to consume a fader playback for it. So I tried on the Titan Mobile to assign this to upper right free grey button.
Regards,
Nicolas
If possible I recommend you try v10.1 which is now available to download. One of the headline features of this version is a complete overhaul of the BPM masters with huge improvements. I have tested this and tap tempo on BPM masters assigned to the executor buttons works.
