Hello fellas.
I've been wondering if there is a way to set Key Frame Shapes recorded in a cue list, to only fire once. This would be great as i often use the Key Frame Shape tool to create Fly Outs. But instead of having a series of cues in my stack doing a single Fly Out, i would like a single Key Frame Shape Cue to do just one repeat.
Is this by any chance possible? I've gone through the manual a couple of times but with no succes.
Cheers
Key Frame Shape - Fire once
Cue1Design
Re: Key Frame Shape - Fire once
There isn't currently an option to do that with (key frame) shapes, you could perhaps try setting the time of the cue so that there is only time for the shape to run once.
Cue1Design
With Key Frame in brackets, is there a way to do it with normal shapes?
No, it is the same for all shapes including key frame shapes and normal shapes.
