Random Key Frame
kimwida
Random Key Frame
Postby kimwida » 23 Mar 2017, 16:15
I made a random dimmer chase using playback options' play order to random.
And I found that if I make it with dimmer key frame, it will be more useful.
But I couldn't make the key frame to be random.
Any advice??
Re: Random Key Frame
Postby niclights » 23 Mar 2017, 17:20
Try setting the direction to random (represented by two lines that cross over). This is not truly random but it generates a random order each time it is selected which will then be used for the spread.
Users browsing this forum: No registered users and 72 guests
