Palette overlap
bercic
Palette overlap
Postby bercic » 08 Feb 2017, 13:09
HI there
Not sure if its supposed to be this way or its a bug, but when i set master overlap and time for pallets its works fine, the only thing that is odd to me is if i later on with overlap still set, hit a fade time via num pad, it fades all fixtures at the same time ignoring overlap value. running v10 on a mobile.
Best Regards Urban
Re: Palette overlap
Postby niclights » 08 Feb 2017, 14:34
I think the logic is that when you enter the numeric menu you are overriding both the time and the overlap as both values are set in that menu.
