Pearl tiger not open
sultahan
Postby sultahan » 03 Feb 2017, 15:20
Hello there. I have a pearl tiger light table but it does not open. It shows the problem in the picture. How to follow a path is necessary. Thanks in advance.
sultahan
Re: Pearl tiger not open
Postby sultahan » 23 Feb 2017, 18:56
Nobody can help?
Postby niclights » 23 Feb 2017, 19:01
Have you tried contacting service?
sultahan
Postby sultahan » 23 Feb 2017, 19:27
I'm trying to do what is written here, but every time it shows the photo in the photo. Would it be useful if I did ECN-0180?
sultahan
Postby sultahan » 23 Feb 2017, 19:29
Whenever the power button is turned on and off, the clock is always the same. Could it be because the battery is over?
Postby Gregory » 27 Feb 2017, 14:34
Lee wrote:It looks like you just need to license the console. First check the battery voltage on the motherboard, with the console switched off this must not be any lower than 3.6volts. If it is lower than this you will have to replace the battery.
To license the console follow the steps below;
Save the two attached files onto a USB stick – with the console switched off insert the USB stick into the console with the two attached files saved on the stick – now switch on the console.
Once booted turn the key switch to System mode, the console will now boot into the AVOS menu from where you can get the console ID. Now go to the link below and submit a license request;
https://www.avolites.com/software/downloads/pearl-2008-tiger/license-software
I am unable to attach the files mentioned above, best thing to do would be to contact Lee in service.
