Show only on Monitor
kimwida
Postby kimwida » 25 Jan 2017, 05:30
Sometimes I need to program in the break time of the concert.
And I want to program and test the show only on my monitor.
Without disconnecting Titan one, is it possible??
I know the "Blind Mode", but I need to test it and don't want people to see that.
clublights
Re: Show only on Monitor
Postby clublights » 25 Jan 2017, 05:34
That is what blind mode means.
Page 212 Section 11.1.10 Blind mode of the V10 TitanOne Manual
kimwida
Postby kimwida » 25 Jan 2017, 05:35
Ok. I found it.
System -> Dmx settings
Delete DMX Output.
kimwida
Postby kimwida » 25 Jan 2017, 05:41
Blind Mode only work in programmer. Isn't it??
When I fire a playback in Blind mode, it show on stage too.
clublights
Postby clublights » 25 Jan 2017, 06:16
yes blind mode is for the programmer.... which is what you said you want to program ....
disabling DMX output you might as well unplug the cable.
Postby niclights » 25 Jan 2017, 08:39
You can change individual playbacks to blind as well via [Playback Options]. However, if you don't need any DMX output at all then just disable DMX or unplug.
