Move Lights before Intensity On
B_Etheridge
Postby B_Etheridge » 06 Jan 2017, 11:47
I've recently purchased a Titan One dongle to use with my four showtec moving heads and a number of par cans.
However, when going between different scenes where I have the moving heads in different positions (i.e. 0% intensity in locate positiion to 100% in a different pan/tilt position) I find that it is quite distracting and not astheticaly pleasing to see the beam of light traveling across the stage.
Hence, my question is this: Is there a way for me to tell moving heads to move to the new position before the intensity level goes up (i.e. black whilst moving)???
Any help is much appreciated! :D :D
BDE
Re: Move Lights before Intensity On
Postby niclights » 06 Jan 2017, 12:20
There is a feature called 'Move in Dark' in Cue Lists. Have a look at section 9.2.4 in the manual.
yyy898
Postby yyy898 » 08 Jan 2017, 20:08
this is also a setting in the menu of most movingheads
Andy Bragg
Postby Andy Bragg » 17 Aug 2017, 16:20
Can MID be accomplished on a single handle or does it have to be a cue list?
I'm using an executor button for a spotlight and I would like it to fade up in position rather than be seen moving into position.
Thanks!
Postby icke_siegen » 20 Aug 2017, 13:12
On single cues this is called preload and can be assigned as key profile to one of the buttons of the handle. E.g. assign the blue button to preload this cue. Then, with the fader down presse the blue button to preload the cue, and then raise the fader.
