Specify fade out parameter on flash button
jakebrightman
Postby jakebrightman » 10 Dec 2016, 21:28
Hi All,
I mainly use Chamsys, but I have got a show next week that I am going to be using a Tiger Touch for.
I am doing some pre-programming at the moment using the simulator software.
To my problem, I have set on the cue, a 2 second fade out time on the memory which is saved to a playback (only one memory not cue stack) with no fade in time set. now when I use the fader I can achieve a snap on and fade out, which i am going to be doing manually to a beat. To make my life easy to hit the beat correctly in the past on Chamsys I have also been able to set the flash button for that playback to adopt the 0 second fade in and 2 second fade out timings.
As I am not an experienced Avolites user I am more than likely missing something, but what I was wondering is there a way any of You know how to do that on Titan? and if so how?
Many Thanks,
Jake
Re: Specify fade out parameter on flash button
Postby niclights » 10 Dec 2016, 21:56
By default the flash action is without times. To enable with times:
- Avo+[Edit Current Key Profile]
(at this point if you are currently using one of the uneditable factory profiles you will be prompted to select an editable one or create a new one - optionally enter a name and then press [Add})
- Press the flash button on the cue
- [Timed Flash]
jakebrightman
Postby jakebrightman » 10 Dec 2016, 22:31
Thankyou very much for your help, knew there must be a way of doing it, worked a treat.
Jake
