Hi - new to Titan and trying to run T1 v10 under w10 with dongle.
When open T1 i get a " cant load show" message. When I try to save a new show I get a "cant save - disk full" (its not) message and the same happens if I try to save to empty usb stick.
The manual for v10 says you can change the default save location but I cant find out how from the user settings section. Neither the "disk" menu or system menu seem to have a command to change the show file save default folder.
I'm getting very frustrated as I can save anything!!
T
saved shows location and problem
Re: saved shows location and problem
I don't know why you got the error, but where in the manual did you read you can change the default saving location ? I can't seem to find that in the manual.
TitanMobile_Man_v10.0.pdf
42 Page, 8 line.
"If you save to hard drive, shows are saved in the folder ‘Documents\Titan\Show Files’, unless you change this in the User Settings. "
I think this is what he read.
42 Page, 8 line.
yup thats the bit I read but cant find any further reference to it in "User Settings" or anywhere else in manual
