How do you change the top right bank of execute/macro buttons so you can use all of them for cues or pallets etc? 7 of them are taken up by workspace shortcuts.
Also where is the view button (or how do you view pallets for editing?)
One more thing, am I correct in thinking you cannot add a TOUCH screen to a Quartz? I've got a job comming up with one, would prefer somthing bigger but thats the desk they've got. I will be using a wing with it also.
Quartz - record to all 20 execute buttons + where is view?
ravehornmegastrobes
Re: Quartz - record to all 20 execute buttons + where is view?
The Open Window button is equivalent to View.
To delete the factory workspace shortcuts press Open Window then Delete and double-tap the macro/executor button.
ravehornmegastrobes wrote:Hi,
you can add a touch screen to the quartz, just connect the screen to the dvi and the usb for touch
ravehornmegastrobes
Great thanks,
Can I use a touch screen and a wing at the same time? there is only 1x usb in the back of the desk.
Would it be ok to use a USB hub? or could I use the usb in the front of the desk for pen drives?
You can use a USB hub if required, ideally use a powered hub to ensure there is enough power for all devices.
On touchscreens the normal advice is to use a screen which is Windows Touch compatible as the drivers are built into the operating system. Installing third party drivers or utilities is not officially supported and may cause the console to become unstable or crash.
Users browsing this forum: No registered users and 82 guests
