midi lead transisitor
24seven
Postby 24seven » 21 Apr 2006, 15:08
Hello all
i have a problem - i am currently building my own visualiser lead the problem i have is the transistor in the instructions it says you need a BC337 transistor but all i can purchase from maplins is a --BC337-16 and from what i can see from online data sheets the BC337 and the BC337-16 have slightly different propertys any one know if this matters also if it does where i can get a BC337 transistor from .
with thanks
Mark W-E
:roll:
Lighting Design -Desk Operation - Tour Management
www.markwynnedwards.com
My area on Avolites
24seven
Postby 24seven » 27 Apr 2006, 01:02
Ok update time -- built the lead took a few mins
IT DOESN'T WORK waaaaa
did the test with the paper clip in the d plug nothing ........then the test with a midi lead and that works so the desk is ok
so back to the lead ....is this not working because i could be the wrong transistor ???? all connections are as they should be .
so i carried on and did the pc side of it would i be correct in thinking you have to set up a computer to computer connection in networks (i have no idea on PC's i use apples ) to activate the COM ports or does visualiser just do it once i have told it the one in use .
Yet again if any one has a clue please let me know
Mark W-E
My area on Avolites
iadwm
Postby iadwm » 11 May 2006, 17:54
Mark,
Did you have Visualiser enabled on the desk ?
Are you running ACDI ?
Just a thought....
Andy
John Peel
www.iadwm.com
24seven
Postby 24seven » 11 May 2006, 18:44
Did you have Visualiser enabled on the desk ?-------YES
Are you running ACDI ? ---- RUNNING WHAT ?
sorry if i am a bit thick but as soon as you add a pc in there iam lost as i am a mac fan
My area on Avolites
iadwm
Postby iadwm » 13 May 2006, 18:08
ACDI is an Avo driver for third party visualiser software (MSD, Capture etc).
http://www.avolitesdownload.com/Downloads/ACDI.stm
When I couldn't get Vis to work with my PC via the dongle (this was before Vis was free), Avo suggested I try ACDI. I did and it worked. It's free to use with Visualiser, you only have to pay a license fee to use it with third party software.
When running ACDI - Source is "COM1", Status "READING" flashes and the green square fades from green to black.
Vis should be set to simulator (F5).
Of course, if your cable doesn't work, then none of this will make any difference!
HTH
Andy
John Peel
www.iadwm.com
Users browsing this forum: Bing [Bot] and 9 guests
