I made two chases and three cues on the five faders.
First chase has two steps in which all fixtures go white and black.
Second chase is changing all fixtures to three colors.
The cues are recorded to red, blue and green.
In Takeover Run Mode of my Pearl Tiger.
When all of the faders are raised, I can switch to the chases and cues immediately by pushing swop button on the faders.
In Run Mode of Titan One.
From cue to cue and from chase to cue, it works but I can't switch from chase to cue.
And Titan manual say that there is Takeover Run Mod but I can't find one.
When I hit "AVO" to "Select Key Profile". It shows only Run mode, Program mode and Threatre mode.
I tried many other key profiles and playback options. But I couldn't solve it.
Swop from chase to cue
Re: Swop from chase to cue
Unfortunately I can't think of any way to do this at the moment. The behaviour in Titan is different to Classic.
Perhaps you could look at a combination of cuelists that autoload/fire macros that kill other running playbacks? This should work albeit a bit more involved to setup. See here for an example.
Users browsing this forum: No registered users and 77 guests
