Personality Builder Shapes
intereact
Postby intereact » 03 Oct 2016, 13:58
Hi
My Current Fixture that i build in the personality Builder have this ONLY shapes. Image
How can i possibly get all the shapes like this from other moving heads Image
It seems that my fixture's shape is few.
I use Beam230 7R
Thank you =)
Re: Personality Builder Shapes
Postby Gregory » 03 Oct 2016, 14:14
The shapes that are displayed are based on the attributes that are available in the selected fixtures, for example Red, Green and Blue shapes will only be available for fixtures that have attributes with IDs called Red, Green and Blue respectively. Other shapes such as Rainbow RGB and RGB Strobe also depend on those attributes. If the fixture should have those attributes double check in the personality that they are named correctly, for example the attribute ID should be Pan, not Pan1 or any other variation, for the shapes involving pan to appear. The attributes shown in the top right of Personality Builder will normally have the correct attribute IDs to work with shapes (although if you add them multiple times a number will be appended).
Users browsing this forum: Google [Bot] and 9 guests
