Version 10 PC hardware requirement
watty
Postby watty » 26 Sep 2016, 20:21
I have version 10 running on a mini PC/touchscreen and it works fine.
I am running a version 9 backup system on a Tosh laptop and would like to upgrade this to version 10 to keep the show files cross compatible. The laptop spec is Intel core i3 2310M 2.1 GHZ with 4GB of ram.
Will V10 run OK on this spec Laptop and if I do upgrade to V10, how easy would it be to go back to V9 if I encounter problems?
Thanks in advance, Steve
Re: Version 10 PC hardware requirement
Postby icke_siegen » 26 Sep 2016, 20:31
While the i3 doesn't meet the official minimum specs, there is a good chance it might suffice - depending from the size of your actual shows. Honestly, I would just try it - and if it doesn't work out, then simply go back.
Going back simply means: (save all Titan Data, just in case), uninstall Titan, reboot, re-install the other version (which requires another reboot). The licence as well as your data _should_ survive this. The whole process takes just a couple of minutes.
