Adjust the capture window size
zahoorjury
Postby zahoorjury » 04 Sep 2016, 19:56
Hi all, I accidentally adjust the capture visualiser and capture visualiser setting at their minimum look , even I cannot get the tab button of adjustment in it , how to retrieve these windows to its mean positions
Re: Adjust the capture window size
Postby Gregory » 04 Sep 2016, 20:45
With the window active (white title bar) press the View button the select softkey C Window Options and then again softkey C Size and Position. This should resize the window back to one of the standard quarter positions.
zahoorjury
Postby zahoorjury » 14 Sep 2016, 20:12
:D , thank sir , and in Titan libraries from where can I patch a Dimmer personality like , PAR 64 ( lamp CP 61 , CP62 & CP 64 ) and 1k , 2k profiles etc , and LED PAR RGB .
Using Titan one V10 capture visualiser,
Regards
Postby icke_siegen » 15 Sep 2016, 06:20
A dimmer, patched in Titan in the traditional way, is represented as spot in Capture.
If you really need distinct Capture symbols for PARs then patch them in Titan as Generic Par 36, Generic PAR 56, Generic PAR 64. If you don't find these fixtures then you need to update your personality library.
I don't know of fresnels - but then, just patch them as dimmer channels :)
zahoorjury
Postby zahoorjury » 30 Sep 2016, 20:33
Kindly name a RGB LASER for the Capture in V10
Regards
Postby niclights » 30 Sep 2016, 20:53
As far as I know it is not possible to simulate DMX lasers.
The full version of Capture Atlas provides laser simulation from Pangolin & LaserAnimation controllers.
